Edit: Oh never mind, this refers to the folder and not to the the sub file format.
In the OCR tab, you can create "cleared TXT images" after running a search. This seems to work as it should. Empty timings also are nearly perfect.
The button below "Create Sub from TXTResults" SEEMS to offer the option to create Sub files (as opposed to srt files).
I'd be interested in that because then you could used other software than fineprint to OCR the results. SubtitleEdit for example can be used on Sub files.
But it doesn't really seem to work... Or am I expecting the wrong results here?
This is nøt å signåture.™ -
Try InpaintDelogo - advanced logo removal & hardcoded subtitles extraction, it usually gives better results than VideoSubFinder.
To OCR images with SubtitleEdit you need to import them in File>Import> Images. nOCR method is good for big images.
AviSynth Script error: there is no function named "setmtmode"
By minimax in forum RestorationReplies: 27Last Post: 10th Sep 2021, 04:57 -
cleartxt image on videosubfinder doesn't work correctly
By faridkhoir14 in forum SubtitleReplies: 0Last Post: 31st Dec 2019, 22:05 -
How to automatic execute a function of "Codec Tweak Tool"?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 10th Jul 2018, 10:04 -
Germany's "spiegel.de" vid doesn't work right on any browser
By jgg in forum Newbie / General discussionsReplies: 5Last Post: 11th Feb 2018, 16:33 -
qtgmc error "there is no function named removegrain"
By codemaster in forum Video ConversionReplies: 6Last Post: 17th Jun 2017, 14:51
